[Proj] Local Level
Eran Burstain burstain at gmail.com
Thu Nov 13 08:02:10 PST 2008
So, is it in Proj.4 (EPSG dataset coordinate operation method code 9836), is
someone working on it ? (it should be quite simple, mathematically).
On Thu, Oct 23, 2008 at 1:30 PM, Noel Zinn <ndzinn at comcast.net> wrote:
>  FYI, the current version of the EPSG Guidance Note 7-2 presents the
> algorithm to do this (called topocentric coordinates by the EPSG).  If this
> is not in proj4 already, I would support its inclusion.  Also FYI, if the
> vertical dimension of topocentric coordinates is ignored, the remaining
> horizontal coordinates define the ellipsoidal orthographic projection.
> –Noel Zinn
> *From:* proj-bounces at lists.maptools.org [mailto:
> proj-bounces at lists.maptools.org] *On Behalf Of *Eran Burstain
> *Sent:* Thursday, October 23, 2008 4:55 AM
> *To:* proj at lists.maptools.org
> *Subject:* [Proj] Local Level
> Hi !
> Can I convert a point from geocentric to Local Level Projection (also
> called Local Tangent Plane) ?
> It's only Rotation and Shift from the geocentric representation.
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.175 / Virus Database: 270.8.2/1740 - Release Date: 10/22/2008
> 7:24 PM
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20081113/731e1534/attachment.html>
