[Proj] Any access to geodetic[sic] functions ??
Gerald I. Evenden
geraldi.evenden at gmail.com
Thu Nov 13 14:59:49 PST 2008
On Thursday 13 November 2008 1:18:27 pm Christopher Barker wrote:
> Frank Warmerdam wrote:
> > I'd like to encourage those interested to setup a page of pointers to
> > resources on geodesic distance calculations on the PROJ.4 Trac site.
> Done:
> http://trac.osgeo.org/proj/wiki/GeodesicCalculations
> Could those of you that actually know what you are talking about please
> take a look and correct and/or add to it?
> I also do think it would be nice to publish a C lib for this somewhere
> -- Gerald, are you willing to put your C code out there, and see if
> someone (maybe me) wants to work with it?
I will have to dig it out. As I recall it was something that was preprocessed
by f2c and then postedited by me into something a little more readable.
OK, found a recoded copies dated Feb., 2003. I do not know if the NGS stuff
has been updated since then. The boiler plate on one of the files reads:
/* Translation of NGS FORTRAN code for determination of point at
** distance 's' and azimuth 'Az12' from point 'phi1','lam2'. Good for
** any values that are less than antipodal distance.
** INPUT
** phi1, lam1 -- latitude and logitude of first point in radians.
** Az12 -- azimuth to second point from first point in radians clockwise
** from North.
** s -- distance from first to second point normalized by major
** elliptical axis (i.e. / a).
** f -- elliptical flattening.
** OUTPUT
** phi2, lam2 -- latitude and longitude of second point.
** Az21 -- azimuth from second point back to first point.
#include <math.h>
#define PI 3.141592653589793238462643
#define EPS 5e-14
void
for_geodesic(double phi1, double lam1, double Az12, double s, double f,
double *phi2, double *lam2, double *Az21) {
The whole file consists of this one procedure and a main program that executes
it with a simple test.
There is a similar file for the inverse case.
> > A link to such info from the FAQ would also likely be appropriate.
> Also done.
> -Chris
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
More information about the Proj
