[Proj] Any access to geodetic[sic] functions ??
Gerald I. Evenden
geraldi.evenden at gmail.com
Fri Nov 14 13:04:53 PST 2008
On Friday 14 November 2008 3:18:23 pm Christopher Barker wrote:
> Gerald I. Evenden wrote:
> > On Thursday 13 November 2008 1:18:27 pm Christopher Barker wrote:
> I'd like to see it.
Ok, you asked for it. The inverse problem:
/* Translation of NGS FORTRAN code for determination of true distance
** and respective forward and back azimuths between two points on the
** ellipsoid. Good for any pair of points that are not antipodal.
** INPUT
** phi1, lam1 -- latitude and longitude of first point in radians.
** phi2, lam2 -- latitude and longitude of second point in radians.
** f -- elliptical flattening.
** OUTPUT
** Az12 -- azimuth from first point to second in radians clockwise
** from North.
** Az12 -- azimuth from second point back to first point.
** s -- distance between points normalized by major elliptical axis
** (i.e. a * s to get distance).
#include <math.h>
#define PI 3.141592653589793238462643
#define EPS 5e-14
void
inv_geodesic(double phi1, double lam1, double phi2, double lam2, double f,
double *faz, double *baz, double *s) {
static double c, d, e, r, x, y, sa, cx, cy, cz, sx, sy, c2a, cu1, cu2,
su1, tu1, tu2, ts;
r = 1. - f;
tu1 = r * tan(phi1);
tu2 = r * tan(phi2);
cu1 = 1. / sqrt(tu1 * tu1 + 1.);
su1 = cu1 * tu1;
cu2 = 1. / sqrt(tu2 * tu2 + 1.);
ts = cu1 * cu2;
*baz = ts * tu2;
*faz = *baz * tu1;
x = lam2 - lam1;
do {
sx = sin(x);
cx = cos(x);
tu1 = cu2 * sx;
tu2 = *baz - su1 * cu2 * cx;
sy = sqrt(tu1 * tu1 + tu2 * tu2);
cy = ts * cx + *faz;
y = atan2(sy, cy);
sa = ts * sx / sy;
c2a = -sa * sa + 1.;
cz = *faz + *faz;
if (c2a > 0.) cz = -cz / c2a + cy;
e = cz * cz * 2. - 1.;
c = ((c2a * -3. + 4.) * f + 4.) * c2a * f / 16.;
d = x;
x = ((e * cy * c + cz) * sy * c + y) * sa;
x = (1. - c) * x * f + lam2 - lam1;
} while (fabs(d - x) > EPS);
*faz = atan2(tu1, tu2);
*baz = atan2(cu1 * sx, *baz * cx - su1 * cu2) + PI;
x = sqrt((1. / r / r - 1.) * c2a + 1.) + 1.;
x = (x - 2.) / x;
c = (x * x / 4. + 1.) / (1. - x);
d = (x * .375 * x - 1.) * x;
*s = ((((sy * sy * 4. - 3.) * (1. - e - e) * cz * d / 6. - e * cy) *
d / 4. + cz) * sy * d + y) * c * r;
/* -- cut here and discard this and following lines after testing -- */
#define DR .0174532925199432958
main() { /* simple test */
double lata, lona, latb, lonb;
double s, A21, A12,
a = 6378206.4, f = 1/294.9786982138; /* Clark 66 */
inv_geodesic(33.*DR, -91.5*DR, 42.*DR, -86.25*DR, f,
&A12, &A21, &s);
printf("fwd Az: %.9f, back Az: %.9f, distance: %.4f\n",
A12/DR, A21/DR, s * a);
inv_geodesic(0.*DR, 0*DR, 0.01*DR, 1*DR, f,
&A12, &A21, &s);
while (scanf("%lf %lf %lf %lf",&lata,&lona,&latb,&lonb)==4) {
inv_geodesic(lata*DR,lona*DR,latb*DR,lonb*DR, f,
&A12, &A21, &s);
printf("dist: %.9f, Az12: %g, Az21: %g\n",s*a,A12/DR,A21/DR);
/* test prog should yield:
fwd Az: 23.361326677, back Az: 206.568647963, distance: 1100896.2093
end of file
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
More information about the Proj
