[Proj] Winkel II corrections, etc.
Paul B. Anderson
pbander at cavtel.net
Thu Nov 20 11:42:18 PST 2008
- Gerald,
Even though John Snyder originally thought that Winkel was refering to the
Equal-area Mollweide (1977) and later realizing that is was a Equidistant
variation (1993) that Winkel was talking about, John's formulas are still a
valid map projection. I believe that the earlier proposed 'Winkel II
(Snyder)' would be OK, or even Winkel II (Snyder's Variation). But, Map
projection naming conventions usually end up with the Originator's name
first, a hyphen, then the Modifier's name second (as in 'Winkel-Snyder
projection'). This sometimes results in confusion as to what the
Originator's projection was, but then a future version of John Snyder will
have something to write about.
Take Care,
- Paul
Paul B. Anderson FCCS (USN, Retired)
Kingsport, TN native living in Norfolk, VA
My Map Projection web site:
http://www.csiss.org/map-projections/index.html
On Thu, Nov 20, 2008 at 1:40 PM, Gerald I. Evenden <
geraldi.evenden at gmail.com> wrote:
> Libproj4 code corrections regarding Winkel II and no_name projection are
> made
> available at:
> http://members.verizon.net/~gerald.evenden/proj4/
> in the 11/20 files. The updated manual is not quite ready---takes longer
> to
> update the manual than correct the code. ;-(
> Also, Apian II was made a part of Eckert III group
> The whole religious complexion of the modern world is due
> to the absence from Jerusalem of a lunatic asylum.
> -- Havelock Ellis (1859-1939) British psychologist
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20081120/e78a0d90/attachment.html>
More information about the Proj
