[Proj] NAD27 and WGS84 woes
Michal Migurski
mike at stamen.com
Fri Nov 21 00:26:08 PST 2008
Hello,
I'm having some difficulties with conversions between these two
projections:
+proj=utm +zone=10 +ellps=clrk66 +datum=NAD27 +units=m +no_defs
+proj=latlong +ellps=WGS84 +datum=WGS84 +no_defs
I'm seeing what looks like datum shift: when I convert between the two
using cs2cs and do a visual comparison to google maps (via http://getlatlon.com
), I get east/west shifts of approx. one city block. The reference
point I'm using is in Oakland CA, (37.804732, -122.258477). I'm
expecting to see it projected to (565345, 4184205) but instead I'm
getting (565278, 4184204), about 70m off.
I'm trying to use this elevation data from USGS, I need to have it
match the mercator projection used by OpenStreetMap:
http://bard.wr.usgs.gov/htmldir/dem_html/
I've searched for clues on how to approach this, and found these two
old threads:
http://lists.maptools.org/pipermail/proj/2000-July/000088.html
http://lists.maptools.org/pipermail/proj/2006-February/002122.html
The first seems to indicate that PROJ does this conversion seamlessly,
while the second recommends adding a +towgs84 parameter to the NAD27
projection. I've tried this, and I don't see any difference in the
numbers.
Any hints?
-mike.
michal migurski- mike at stamen.com
415.558.1610
More information about the Proj
