[Proj] Datum shift for Dutch maps 1850-2000
Frank Warmerdam
warmerdam at pobox.com
Wed Nov 26 09:47:00 PST 2008
Jan Hartmann wrote:
> This certainly makes a difference! Adding +nadgrids=@null to the
> original definition gives a map with a 120m South shift, still too much
> but nearing a solution. Isn't this a bug in PROJ? I did not request a
> datum shift, and neither the from-projection, nor the to-projection had
> a datum defined, only ellipsoids. I am using Proj 4.6.1.
Jan,
An ellipsoid/geocentric based datum shift should not be done if no towgs84
or nadgrids value is provided with 4.6.0 or later. If you believe there is
a bug please file a detailed ticket showing exactly what you were doing.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
