[Proj] Local Level
Noel Zinn ndzinn at comcast.net
Thu Oct 23 04:30:26 PDT 2008
FYI, the current version of the EPSG Guidance Note 7-2 presents the
algorithm to do this (called topocentric coordinates by the EPSG).  If this
is not in proj4 already, I would support its inclusion.  Also FYI, if the
vertical dimension of topocentric coordinates is ignored, the remaining
horizontal coordinates define the ellipsoidal orthographic projection.
-Noel Zinn
  _____
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Eran Burstain
Sent: Thursday, October 23, 2008 4:55 AM
To: proj at lists.maptools.org
Subject: [Proj] Local Level
Hi !
Can I convert a point from geocentric to Local Level Projection (also called
Local Tangent Plane) ?
It's only Rotation and Shift from the geocentric representation.
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.175 / Virus Database: 270.8.2/1740 - Release Date: 10/22/2008
7:24 PM
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20081023/c87c3f6d/attachment.html>
