[Proj] Transverse Mercator algorithm
Charles Karney
ckarney at sarnoff.com
Tue Sep 2 14:46:31 PDT 2008
Frank:
I noticed an E-mail (dated 2008-05-27) from you to the proj mailing list
concerning the availability of an accurate Transverse Mercator
algorithm. If you're still in need of this, I have recently implemented
and tested the version given in
http://docs.jhs-suositukset.fi/jhs-suositukset/JHS154/JHS154.pdf
and I can send you a copy. This is LGPL'ed C++ code, but you can easily
redo the transcription from this report if you need to use another
licence.
I've replaced with formulas in this paper for meridian convergence and
scale with more accurate ones.
The forward and reverse transforms give ~1um accuracy over quite a
large area. The accuracy here is defined as the maximum of
forward transform compared with the exact result
discrepancy when applying forward transform followed by reverse
The following table summarizes the accuracy (for WGS84)
dx = max(forward error, forwards/reverse error)
dgam = max discrepancy in meridian convergence
dk = max relative error in scale
set dx dgam dk
x<50e5 74um 0.02" 0.02%%
x<20e5, y<99e5 1.1um 1e-4" 3e-4%%
x<5e5, y<96e5 0.22um 9e-8" 1e-6%%
x<4e5, y<95e5 0.21um 3e-8" 4e-7%%
(x,y = easting,northing with no offsets).
In addition, I've computed additional terms in the series for the
transformations so that even more accurate transforms can be computed
(e.g., using long double).
Finally, the "exact" results I benchmarked these against are obtained
from a macsyma implementation using elliptic integrals and arbitrary
precision arithmetic (usually I use 100 digits). I was originally
planning to code this implementation up into C++, but there are a few
loose ends in this code and stop it from being industrial strength.
(These are: checking for the correct branch cut being used in inverse
trig functions; picking safe starting values for Newton's method for the
inverse of some functions; and, related, ensuring that the correct root
is returned.) I'm happy to send you this code too. In case you're
unfamiliar with macsyma, it's an old computer algebra system written at
MIT. It can be installed on many Linux distributions with "yum install
maxima".
Charles Karney <ckarney at sarnoff.com>
Sarnoff Corporation, Princeton, NJ 08543-5300
URL: http://charles.karney.info
Tel: +1 609 734 2312
Fax: +1 609 734 2662
More information about the Proj
