[Proj] Transverse Mercator algorithm
Charles Karney ckarney at sarnoff.com
Thu Sep 4 20:38:59 PDT 2008
Gerald I. Evenden wrote:
>>> It'll take a day or so to make my macsyma code for the exact transverse
>>> Mercator transformation presentable.
> WARNING: anyone doing test with this script needs to know that the scale
> factor is also set to 0.9996.  The ellipsoid was reference OK but not knowing
> the scale factor had be set had me running around in circles for a minute.
Well, I did say the documentation was meager!  Use
   setparams(a,invf,k0)$
to set the major radius, inverse flattening, and central scale factor.
The default is
   setparams(6378137b0, 298.257223563b0, 0.9996b0)$
appropriate for UTM applications.  (But note that no false easting or
false northing is applied.)
Charles Karney <ckarney at sarnoff.com>
Sarnoff Corporation, Princeton, NJ 08543-5300
URL: http://charles.karney.info
Tel: +1 609 734 2312
Fax: +1 609 734 2662
