[Proj] Relationship between transverse Mercator algorithms
Mikael Rittri
Mikael.Rittri at carmenta.com
Thu Sep 11 01:26:54 PDT 2008
> >Relationship betweeen transverse Mercator algorithms by Charles Karney
> I have never read such a clear and concise explanation of the differences
> and similarities between the various TM algorithms. Thank you!
> Irwin Scollar
Yes indeed! Thanks from me, too.
However, I'm wondering about a detail of how the errors are defined.
Charles Karney wrote (http://lists.maptools.org/pipermail/proj/2008-September/003737.html):
> For each set, define
> dxn = max(error in forward transformation,
> discrepancy in forward and reverse transformations)
> for nth order method (order e^(2*n))
Has the nominal error in the forward transformation been divided by the local
scale factor?
That is to say, I think understand the second part, the discrepancy
between forward and inverse. If you start with P, do forward and then
inverse, getting Q, then P and Q are both expressed in longitude and latitude,
so the distance between P and Q is measured in true meters on the ground,
I suppose.
But if you do forward projection from P, getting (N0,E0) from your exact algorithm,
and (N1,E1) from a Krüger-like algorithm, then the error is - primarily - expressed
in projected coordinates. Let us say there were a difference of 1 meter in projected
coordinates at mu = 60 degrees. Then, since the local scale factor there would be
about 2, the true difference on the ground is just half a meter. In some sense.
If you did not divide by the local scale factor, then I don't understand how you
can take the max of the two kinds of error, since one is expressed in true meters
and the other is expressed in nominal (projected) meters.
I hope I am not talking nonsense here.
Again, many thanks for the lucid explanations.
Mikael Rittri
Carmenta AB
Box 11354
SE-404 28 Göteborg
Visitors: Sankt Eriksgatan 5
SWEDEN
Tel: +46-31-775 57 37
Mob: +46-703-60 34 07
mikael.rittri at carmenta.com
www.carmenta.com
More information about the Proj
