[Proj] Unknown projection?
Paul B. Anderson pbander at cavtel.net
Sat Sep 13 07:59:24 PDT 2008
- Janne,
Your map graphic appears to be in the Winkel Tripel map projection. I would
also suggest that it is using Oswald Winkel's original selection of 50.46667
degrees as the Special Parallel.
Note that by the 1950s John Bartholomew was using a special parallel of 40
degrees for his version of the Tripel, giving his graphic a more flattened
appearance in the Y direction.
- Paul
Paul B. Anderson FCCS (USN, Retired)
Kingsport, TN native living in Norfolk, VA
My Map Projection web site:
http://www.csiss.org/map-projections/index.html
----- Original Message -----
To: <proj at lists.maptools.org>
Sent: Saturday, September 13, 2008 8:38 AM
Subject: [Proj] Unknown projection?
> Hello,
> I have a picture from 60's and I can not figure out what is the projection
> used. Can anybody help me?
> Here is the map:
> http://i140.photobucket.com/albums/r38/_videos_/maps/WorldRtsL.jpg
> http://s140.photobucket.com/albums/r38/_videos_/maps/WorldRtsL.jpg
> Regards: Janne
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
