[Proj] Non - earth projection
Klemen S. klemen.sorcnik at gmail.com
Tue Sep 23 10:43:39 PDT 2008
Thank you for your answer.
So if i understand you right i must convert layers with nonearth
coordinate system into appropriate real world coordinate system
if i want use  WMS service ?
Thank you for you answer.
Klemen
View this message in context: http://www.nabble.com/Non---earth-projection-tp19614234p19633142.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
