[Proj] cs2cs output file
Rich Westfall richwestfall at sbcglobal.net
Wed Sep 24 08:56:24 PDT 2008
Hello,
I’m trying to get cs2cs script to pass other fields besides the XYZ
from an input text file out to a text file but only seem to be getting
the xyz to come over and nothing else.
Here is the transformation.
cs2cs +init=epsg:2227 +to +init=epsg:4326 -f '%.4f' -s c:\proj
\test.txt >c:\proj\example.txt
Which is passing the data correctly just not the other fields. Fields
are seperated by white space.
I have been using the win32 executable.
I'm not sure what I am doing wrong.  How do I get the other fields to come
over?
Thank you for any help,
Rich
View this message in context: http://www.nabble.com/cs2cs-output-file-tp19652024p19652024.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
