[Proj] ERROR 6: No translation for Lambert Conformal Conic to PROJ.4 format is known.
Hermann Peifer peifer at gmx.eu
Wed Apr 1 05:59:24 PDT 2009
Is this simply yet another unsupported projection, or could something
else be wrong?
Thanks in advance, Hermann
known.
Failed to create coordinate transformation between the
following coordinate systems.  This may be because they
are not transformable, or because projection services
(PROJ.4 DLL/.so) could not be loaded.
Source:
PROJCS["French Lambert II Carto",
     GEOGCS["NTF (Paris meridian)",
         DATUM["NTF (Paris meridian)",
             SPHEROID["Clarke_1880_IGN",6378249.2,293.4660213]],
         PRIMEM["Paris",0.0],
         UNIT["Degree",0.017453292519943295]],
     PROJECTION["Lambert Conformal Conic"],
     PARAMETER["Standard_Parallel_1",45.898919],
     PARAMETER["Standard_Parallel_2",47.696015],
     PARAMETER["Latitude_Of_Origin",46.800000],
     PARAMETER["Central_Meridian",2.337229167],
     PARAMETER["False_Easting",600000.000000],
     PARAMETER["False_Northing",2200000.000000],
     UNIT["Meter",1.000000000000]]
Target:
GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.257223563,
             AUTHORITY["EPSG","7030"]],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0,
         AUTHORITY["EPSG","8901"]],
     UNIT["degree",0.01745329251994328,
         AUTHORITY["EPSG","9122"]],
     AUTHORITY["EPSG","4326"]]
