[Proj] Problems using grid shift files
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Fri Apr 3 06:49:56 PDT 2009
Thanks Paul! It's getting clearer and clearer. I'll give it a try before
coming back and moaning :)
regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: Paul Kelly [mailto:paul-grass at stjohnspoint.co.uk]
> Gesendet am: Freitag, 3. April 2009 14:58
> An: Ziegler Stefan
> Cc: proj
> Betreff: Re: AW: Re: AW: Re: [Proj] Problems using grid shift files
> Hello,
> I think it would help if you give an example of one of the
> transformations
> that gave the incorrect results, with the exact cs2cs
> command-line you
> used and test points.
> On Thu, 2 Apr 2009, Ziegler Stefan wrote:
> > Mmmmh, I think this is beyond my mental skills ;-) So I
> start with some
> > questions: what is a pivot datum? And how can I chain datum
> > transformation (without piping in the shell)? How does proj does a
> > re-projection? I assumed something like: projection A -> ellipsoid A
> > ----> here comes the datum transformation ----> ellipsoid B ->
> > projection B. So if I know the accurate relation between
> ellipsoid A and
> > B (like the +towgs84 params) I'm able to reproject more or
> less exact?
> No, there is generally an extra stage:
> Source Datum --> datum transformation A --> Pivot datum --> datum
> transformation B --> Target Datum
> Only when either your source or target datum is the same as the pivot
> datum is there only one datum transformation. For all other
> cases you need
> two sets of datum transformation parameters, for the source
> and target
> datum to some intermediate pivot datum. Parameters for use of
> WGS84 as a
> pivot datum are well defined for most datums. But in your
> case when you
> want to use CH1903+ as a pivot datum instead you need to
> calculate a new
> set of datum transformation parameters.
> As of yet I'm not sure exactly how to calculate the new
> parameters but if
> you post some details of the conversion you're trying to do with some
> sample points, maybe someone will be able to work it out for you.
> Paul
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090403/82abd342/attachment.html>
More information about the Proj
