[Proj] Some questions
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 3 12:54:51 PDT 2009
support.mn at elisanet.fi wrote:
> Is there any easy way to open the projection and datum shift ellipsoids
> for the end user to be altered in those cases where required?
> For example something like:
> pellps=.....
> dellps=.....
> where "pellps" would stand for "projection ellipsoid" and
> "dellps" for "datum ellipsoid".
> and when both are the same, just normal
> ellps=....
> where "ellps" stands for both datum and projection. That
> would not alter the existing definitions, but allow more
> accurate control of the ellipsoids involved.
Janne,
No, no such capability has been implemented. I'm still not too keen
on doing so either for reasons previously stated.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
