[Proj] Minor initialization problem
Gerald I. Evenden
geraldi.evenden at gmail.com
Sat Apr 25 10:22:37 PDT 2009
It seems I ran into a hole in the C specification regarding arrays of constant
chars which make the compilation of proj_init exude a warning but will
compile OK.
I was hoping to use a construct making the character string array elements of
argv as type const. But that is either impossible or impractical. However,
internal usage of the arrays are as const even though the prototype is
void *proj_init(int, char **);
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
More information about the Proj
