[Proj] Lambert Conformal Conic
Karney, Charles ckarney at Sarnoff.com
Sun Apr 26 17:01:16 PDT 2009
Another example of frozen-in approximate constants...
geotrans (thru at least version 2.4.2) defines the latitude of true
scale for the UPS projection as 81.114528 (see definition of
MAX_ORIGIN_LAT in ups/ups.c).  However, if we assume that UPS is defined
as having a scale of 0.994 at the pole, then the latitude of true scale
is really 81.11451786859362545 or so.
I reported this to the geotrans maintainers in July of last year and
they declined to fix it because doing so would cause their (presumably
incorrect) tests to fail!
Charles Karney <ckarney at sarnoff.com>
Sarnoff Corporation, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
Fax: +1 609 734 2662
