[Proj] ITRF96/UTM 36N conversion
Gerald I. Evenden geraldi.evenden at gmail.com
Fri Aug 7 07:50:01 PDT 2009
On Friday 07 August 2009 10:38:20 am Jose Gonçalves wrote:
> In order to convert UTM-36N to long-lat with output in decimal degrees you
> can use the following PROJ command line:
> proj -I -f "%.9f" +ellps=WGS84 +proj=utm +zone=36
> You must reformat your file so that each line starts with Easting
> (E) and Northing (N), in this order (your file has ID N E ...) and then the
> rest of the data.
As I indicated in my previous email, use [l]proj -r option to reverse meaning
of input sequence.   NO need to reformat input!
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
