[Proj] ERROR 6: No translation for Double_Stereographic to PROJ.4 format is known.
Hermann Peifer
peifer at gmx.eu
Tue Aug 11 10:06:13 PDT 2009
As far as I remember: Oscar provided the requested test points, so I would guess that the double stereographic projection is now supported
Hermann
-------- Original Message --------
Subject: Re:ERROR 6: No translation for Double_Stereographic to PROJ.4 format is known.
To:
Date: 02/04/2009 17:43
> I can look up some official test points in my files, including references to
> more or less authoritative sources. Will take a few days, around Sunday
> perhaps.
> The latest versions of the RDNAP software (Netherlands) indeed do grid
> interpolation.
> The Dutch Kadaster has/had an on-line transformation tool without grid
> interpolation, but with Schreiber polynomials, including a small error
> however.
> Prince Edward test points are described in a Technical Report (no. 48 I
> believe).
> Romanian test points can be obtained from a Hungarian Excel application by
> Gábor Timár.
> Oscar van Vlijmen
> From: "Frank Warmerdam" <warmerdam at pobox.com>
> To: "PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
> Sent: Tuesday, March 31, 2009 9:27 PM
> Subject: Re: [Proj] ERROR 6: No translation for Double_Stereographic to
>> OvV_HN wrote:
>>> I don't get it. I always thought the existing PROJ (and libproj) function
>>> sterea was a full implementation of the double stereographic projection,
>>> suited for Dutch RD, New Brunswick / Prince Edward Island stereo and
>>> Romanian Stereo 70.
>> Oscar,
>> Well, that is possible. Is someone willing to do some leg work confirming
>> if that is the case, and documenting the correct formulation of the
>> coordinate systems described in http://trac.osgeo.org/gdal/ticket/2487
>> for PROJ.4? Some sample test points would also be helpful. Given that
>> I would be happy to update GDAL to support double stereographic and
>> update some other resources.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
