[Proj] problem in projection
    Milo van der Linden
    milovanderlinden at gmail.com
    Tue Feb 24 07:51:44 PST 2009
Hello Zahid,
You might probe around on http://spatialreference.org to see if you can
query into the right projection.
Best of luck!
Milo
Zahid Parvez wrote:
> hi
> I have a shape file which I have to import in GRASS. Shape file is
> consists of a shape file, a dbf file and a prj file.
> The prj file has following information.
> PROJCS["BTM",
> GEOGCS["GCS_Everest_1830",
> DATUM["D_Everest_1830",
> SPHEROID["Everest_1830",6377299.36,300.8017]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["False_Easting",500000.0],
> PARAMETER["False_Northing",-2000000.0],
> PARAMETER["Central_Meridian",90.0],
> PARAMETER["Scale_Factor",0.9996],
> PARAMETER["Latitude_Of_Origin",0.0],
> UNIT["Meter",1.0]]
> I will be very grateful if anyone could help me to find the ESPG code .
> Best
> Md. Zahid Parvez
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
