[Proj] Plog GPS Coordinate to Screen
support.mn at elisanet.fi support.mn at elisanet.fi
Thu Jan 8 17:13:13 PST 2009
Hello,
you can use Proj.4 to calculate the map projection (forward or inverse)
to you. It can also do datum conversions relative WGS84.
regards: Janne.
Claudio Bisegni [cbisegni at gmail.com] kirjoitti:
> Hi, i'm new to Proj lib. I wan't to write a software to plog gps
> coordinate to the screen. How can i setup proj to do this work? thank
> in advanced.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
