[Proj] Plog GPS Coordinate to Screen
support.mn at elisanet.fi
Fri Jan 9 09:55:01 PST 2009
You can enter the proj.4 inits directly to MNS for example (see below).
MNS includes a database and there are several thousand different
inits for different maps and areas of the world.
Regards: Janne.
Here is a commercial link:
"Master Navigator Software (MNS) can show your position and
other GPS data on any paper map and several electronic raster
maps, it can also handle up to 8 GPS receivers at the same time
(redundancy). It has 3 years update guarantee. Price 199,- "
http://s136.photobucket.com/albums/q163/MNVideos/?action=view¤t=MNDemo4.flv
http://www.elisanet.fi/master.navigator
Claudio Bisegni [cbisegni at gmail.com] kirjoitti:
> Hi janne, thanks for replay.
> I have done some google search to find a good init param to do the
> work but whitout a great success. Have you some example for proj
> initialization to get this work,
> Thank you in advanced.
> Claudio
> Il giorno 09/gen/09, alle ore 02:13, support.mn at elisanet.fi ha scritto:
> > Hello,
> > you can use Proj.4 to calculate the map projection (forward or
> > inverse)
> > to you. It can also do datum conversions relative WGS84.
> > regards: Janne.
> >> Hi, i'm new to Proj lib. I wan't to write a software to plog gps
> >> coordinate to the screen. How can i setup proj to do this work? thank
> >> in advanced.
> >> _______________________________________________
> >> Proj mailing list
> >> Proj at lists.maptools.org
> >> http://lists.maptools.org/mailman/listinfo/proj
> > Proj mailing list
> Proj mailing list
More information about the Proj
