[Proj] Finding PROJ_LIB from application
Roger Bivand Roger.Bivand at nhh.no
Thu Jan 15 11:23:06 PST 2009
On Thu, 15 Jan 2009, Frank Warmerdam wrote:
> Roger Bivand wrote:
>> Nope, not a chance. Would you accept a patch (same as pj_open_lib() but
>> returning the full path and closing fid)?
> Roger,
> I'm somewhat dubious about the utility of this capability. But if you
> were to offer a patch, I would suggest we add a new function called
> pj_find_lib() that returns the full path given a filename.  Most of
> pj_open_lib() would be migrated into that, and then pj_open_lib()
> would use it.
> I suppose if we are using fopen() to discover files, this will result
> in an extra unnecessary file opening and closing which might suck.  I
> suppose pj_find_lib() could also return the file handle, and pj_open_lib
> would become a very minimal wrapper around it to preserve the old api.
> What I am not likely to accept is a change to the pj_open_lib() ABI.
Frank,
I agree that this is probably overkill, so until I'm under pressure from
users, I'll report the value of PROJ_LIB if present, or its absence if
not. It ough to be enough, and avoids changing things that don't need
changing. In GDAL, I'm using a single call to CSVFilename() to get the
path.
Best wishes,
Roger
> Best regards,
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
