[Proj] gps lat/long to x/y rotated issue
support.mn at elisanet.fi
Mon Jan 26 02:44:12 PST 2009
Hello,
either you have to rotate it 90 degrees back - or swap y to x and x to -y (or
somthing similar, maybe add some false n and e values and experiment
with signs).
Regards Janne.
Claudio Bisegni [cbisegni at gmail.com] kirjoitti:
> Hi folk,
> i use this init string found on google, to make the work in object:
> +title= Google Mercator EPSG:900913 +proj=merc +a=6378137 +b=6378137
> +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null
> +no_defs
> It's work well except that the graf is rotated of 90° clockwise.
> Any one has na idea? I'm new to proj..
> Thanks in advanced.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
