[Proj] Lat-Lon values under different ellipsoides
Frank Warmerdam
warmerdam at pobox.com
Mon Jan 26 08:39:13 PST 2009
Jan Hartmann wrote:
> Hi,
> This is something I have long been banging my head against. I think it
> is a bug, but I am not sure. If I take a lat-lon value, computed on a
> particular ellipsoid, and convert it to the lat-lon value on another
> ellipsoid, I should get a different value, right? (e.g. cs2cs
> +proj=longlat +ellps=bessel +to +proj=longlat +ellps=WGS84). PROJ4
> always gives the same value, but I have an extensive list of coordinates
> of church towers in the Netherlands with their lat-lon values in 1850,
> based an a slightly smaller ellipsoid than we use nowadays, and the
> lat-lon of the same towers derived from our modern RD-system, based on
> the Bessel-ellipsoid, and without the WGS84 correction. There is a
> systematic difference of about 50 meters. If I do the same computation
> with the projected coordinates, I get the correct answer. Moreover, in
> that case the transformation changes when I change the
> ellipse-parameter, something that does not happen with lat-lon coordinates.
> So, is this a bug in PROJ? If so, can someone with geodetic experience
> here explain to me how people can get different lat-lon values for the
> same point, based on astronomical measurements?
Jan,
As of PROJ 4.6.0, the policy is to not attempt any conversion of lat/long
values between coordinate systems where only an ellipsoid is given. So, to
get a datum shift it is now necessary to provide some sort of datum
shift information for both the source and destination coordinate systems.
This is a deliberate change of policy to avoid lots of other complaints in
the past.
I would suggest using something appropriate like +datum=potsdam for your
Bessel data, and +datum=WGS84 instead of +ellps=WGS84.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
