[Proj] Memory leaks using proj.4 DLL
michael.hovenbitzer at bkg.bund.de
Tue Jan 27 04:46:58 PST 2009
Hello List,
I would like to use Proj.4 in a MFC-VisualC-Program (VC++6)
to transform coordinates with the NTv2-method.
Using the newest source of proj4.6.1 I build the proj.dll
and so on. The compilation and linking of my software
went quite well (with only a few problems solved in your list).
But when I start my software I got memory leaks !
Testing the DLL with only one button I could discover that
the DLL is working correct (the transfromed point had the
right coordinates). Using all GUI-Features the transformed
coordinates are wrong, because of memory leaks (the name
of the shift file is seemingly overwritten).
Maybe someone has had a similar problem and can help me
solving my problem.
Thank you in advance !
Best regards
Michael
Federal Agency for Cartography and Geodesy (BKG)
Frankfurt, Germany
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090127/c096ec0d/attachment.html>
More information about the Proj
