[Proj] Memory leaks using proj.4 DLL
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 28 06:24:29 PST 2009
michael.hovenbitzer at bkg.bund.de wrote:
> Frank,
> first of all I would like to point out, that I use the proj.dll
> in my own MFC-VisualC-Program. The call of the functions pj_init_plus()
> and pj_transform() result in memory leaks:
> static const char *pgk2 = "+proj=tmerc +lat_0=0 +lon_0=6 +k=1.000000
> +x_0=2500000 +y_0=0 +ellps=bessel +nadgrids=./BETA2007.gsb +units=m +no defs" ;
> quellsys = pj_init_plus(pgk2) ;
> static const char *put32 = "+proj=utm +ellps=GRS80 +datum=WGS84 +zone=32" ;
> zielsys = pj_init_plus(put32) ;
> pj_transform (quellsys, zielsys, 1, 0, &r, &h, &z) ;
> The following log of the debug mode appear :
> Detected memory leaks!
> Dumping objects ->
> {154} normal block at 0x00463BA0, 15 bytes long.
> Data: <./BETA2007.gsb > 2E 2F 42 45 54 41 32 30 30 37 2E 67 73 62 00
> {153} .....
Michael,
Are you calling pj_free() on all definitions created with pj_init_plus()?
Are you calling pj_deallocate_grids() before program termination?
> The DLL is working, but in most cases the coordinates
> are wrong.
> I would be very happy, if the problem could be solved.
I'm not familiar with BETA2007.gsb, nor your coordinate systems. Generally
it does not make sense to specify datum=WGS84 with an ellipse other than WGS84.
Perhaps you could specify what values you pass in, what values you expect,
what values you get, what your coordinate system definitions are,and why you
think they are appropriate (ie. references to the coordinate systems you are
trying to represent).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
