[Proj] Accuracy Cassini Solder -> lat lon 200m?!
support.mn at elisanet.fi support.mn at elisanet.fi
Fri Jul 3 02:39:09 PDT 2009
Sebastian Schubert [schubert.seb at googlemail.com] kirjoitti:
# ---- From Coordinate System ----
#Cassini
# Cyl, Sph&Ell
# +init=epsg:3068 +proj=cass +lat_0=52.41864827777778
# +lon_0=13.62720366666667 +x_0=40000 +y_0=10000 +ellps=bessel
# +datum=potsdam +units=m +no_defs +towgs84=606.0,23.0,413.0
#--- following specified but NOT used
# +ellps=bessel
# ---- To Coordinate System ----
#Lat/long (Geodetic alias)
# +proj=latlong +datum=potsdam +ellps=bessel +towgs84=606.0,23.0,413.0
Some notes:
There are 3 datums given?
Source datum is "potsdam" and/or (?) "towgs84..."
Destination datum is "towgs84..."
Source ellipse given "bessel", but the program is telling that
it is NOT used?
I am assuming that some wrong ellipse is maybe used (check
postdam)? Or that some datum is not correct, either specified
or used.
Janne./MNS Support
