[Proj] Accuracy Cassini Solder -> lat lon 200m?!
Sebastian Schubert
schubert.seb at googlemail.com
Fri Jul 3 04:03:45 PDT 2009
Dear Jean-Claude, dear all,
* On Friday 03 July 2009, 11:39:31, Jean-Claude Repetto wrote:
> Sebastian Schubert a écrit :
> > I want to convert from Solder system used in the city of Berlin
> > (EPSG:3068) to the standard lat lon system.
> What do you mean "standard lat lon system" ? If you mean WGS84, you
> should try :
> cs2cs -v +init=epsg:3068 +to +init=epsg:4326
merci beaucoup, you were absolutely right! This works.
Thank you,
Sebastian
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090703/8ce76c54/attachment.sig>
More information about the Proj
