[Proj] trying to understand results of reprojecting from epsg 4326 to epsg 31370
Clifford J Mugnier cjmce at lsu.edu
Tue Jul 7 07:53:17 PDT 2009
Consider not changing the signs of the rotation elements.
C. Mugnier
LOUISIANA STATE UNIVERSITY
From: proj-bounces at lists.maptools.org on behalf of Moritz Lennert
Sent: Tue 07-Jul-09 09:14
To: Proj at lists.maptools.org
Subject: [Proj] trying to understand results of reprojecting from epsg 4326 to epsg 31370
Hello,
I'm trying to reproject the following WGS84 Lat-Long (EPSG 4326)
coordinates to the Belgian 1972 projection EPSG 31370:
4.468493 50.856057
Using the official software from the Belgian National Geographic
Institute, I get the following coordinates (confirmed by a contact in
the Institute):
157022.870 171745.084
Using cs2cs +init=epsg:4326 +to +init=epsg:31370, I get
157201.51    171803.24
i.e. way off the official response.
31370 is defined as
+proj=lcc +lat_1=51.16666723333333 +lat_2=49.8333339 +lat_0=90
+lon_0=4.367486666666666 +x_0=150000.013 +y_0=5400088.438 +ellps=intl
+towgs84=106.869,-52.2978,103.724,-0.33657,0.456955,-1.84218,1 +units=m
+no_defs
so datum transformation is defined.
The transformation parameters are confirmed by the Belgian Institute
(http://www.ign.be/FR/FR2-1-2.shtm), which considers ETRS89 to be
equivalent to WGS84:
Paramètres de ETRS89 vers BD72
Tx      106.868628
Ty      -52.297783
Tz      103.723893
Rx      0.336570
Ry      -0.456955
Rz      1.842183
scale   1.0000012747
As these parameters are in the direction fromwgs84, they should be
negated to get the inverse transformation. So, IIUC, 31370 should
actually be defined as:
+towgs84=-106.869,52.2978,-103.724,-0.33657,0.456955,-1.84218,1 +units=m
+no_defs
When I try this, I get:
157080.62       171775.09
Much close, but still no good. The Institute also use a correction grid,
but this should only change accuracy at the centimeter level.
Interestingly enough, when I use the 3-parameter transformation given by
EPSG 1610:
+proj=lcc +lat_2=51.16666723333333 +lat_1=49.8333339 +lat_0=90
+towgs84=-125.8,79.9,-100.5 +units=m +no_defs
I get perfect results:
157022.80    171745.11
Does anyone have an explanation for this behaviour ?
Moritz
Proj mailing list
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090707/fe858495/attachment.html>
