[Proj] trying to understand results of reprojecting from epsg 4326 to epsg 31370
Moritz Lennert
mlennert at club.worldonline.be
Tue Jul 7 09:00:17 PDT 2009
On 07/07/09 16:56, Noel Zinn wrote:
> Consider changing the signs of the three rotations if you can do that
> manually, or the rotation sense of the 7-parameter transformation.
That was it. Thanks also to Clifford for the same hint. Could someone
explain the logic to me ? Why negate the translation, but not the
rotation compared to the WGS84->Bel72 transformation ?
And: should the information linked to EPSG code 31370 be corrected ? How
should I go about doing this ?
Moritz
More information about the Proj
