[Proj] map coordinates in different coordinate system
Wed Jul 8 08:28:15 PDT 2009
stretch wrote:
> I am referencing the proj4js combined and compressed js file, and I am
> referencing the two additional EPSG2054.js and EPSG4148.js, which contain:
> Proj4js.defs["EPSG:2054"] = "+proj=tmerc +south +ellips=WGS84 +datum=WGS84
> +lon_o=31 +k_0=1 +units=m +no_defs";
> and
> The coordinates are changed, but not correctly - i.e they are converted from
> metres to metres, where they should be displaying dd.
> The first thing you will notice is that 2054 is not a standard. Would
> someone be able to verify the correctness of this format?.
> I have successfully translated coordinates previously using just
> "+proj=tmerc +ellips=WGS84 +datum=WGS84 +lon_o=31"
Andrew,
I think the proj4js project uses the MetaCRS mailing list for discussions.
However, I suspect Mike Adair is also on this list.  I'm not to familiar
with the details of proj4js's implementation so I'll speak briefly from
the PROJ.4 point of view.
I am not sure why you say that EPSG:2054 is not a standard. It is a normal
part of the EPSG database. However, it uses the projection method
Transverse Mercator South Orientated.  The normal software used to translate
the EPSG database to a PROJ.4 dictionary does not handle this projection
method since I'm uncertain if it is plain transverse mercator, or if there
is also an implicit change in direction of the Y values (to southings
instead of northings).
I believe that for PROJ.4 the +south parameter is only used with UTM,
not transverse mercator.  So it is likely not being used in this
situation.
I also suspect that +lon_o should be +lon_0 (note use of a zero instead
of a lower case letter "O").
I'm not sure if any of this will help you though.
Best regards,
