[Proj] map coordinates in different coordinate system
OvV_HN ovv at hetnet.nl
Thu Jul 9 09:22:30 PDT 2009
Seems to me that EPSG:2054 is the Lon_0 = 31d Hartebeesthoek_1994 Transverse
Mercator projection.
This has a south-west orientation.
Haven't I read somewhere that you can put a minus sign in front of the k_0
in (lib)proj to get the axes in south-west orientation?
Oscar van Vlijmen
----- Original Message -----
To: <proj at lists.maptools.org>
Sent: Wednesday, July 08, 2009 8:46 PM
Subject: Re: [Proj] map coordinates in different coordinate system
> Frank Warmerdam wrote:
>> I am not sure why you say that EPSG:2054 is not a standard. It is a
>> normal
>> part of the EPSG database. However, it uses the projection method
>> Transverse Mercator South Orientated.  The normal software used to
>> translate
>> the EPSG database to a PROJ.4 dictionary does not handle this projection
>> method since I'm uncertain if it is plain transverse mercator, or if
>> there
>> is also an implicit change in direction of the Y values (to southings
>> instead of northings).
