[Proj] Swiss CORINE: Bessel 1841 Hotine Oblique Mercator Azimuth Natural Origin?
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Fri Jul 10 07:07:44 PDT 2009
Hi Markus
try this:
ogr2ogr shp_dir/ -s_srs epsg:21781 -t_srs epsg:3035 clcbn85p.shp
epsg:21781 is forcing ogr2ogr to use the real swiss prj-definition.
Forget the strange definition in the delivered prj-file.
regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: Markus Neteler [mailto:neteler at osgeo.org]
> Gesendet am: Freitag, 10. Juli 2009 14:59
> An: PROJ.4 and general Projections Discussions
> Betreff: Re: [Proj] Swiss CORINE: Bessel 1841 Hotine Oblique Mercator
> Dear list members,
> I was earlier sending this message to the gdal-dev list without
> answer. trying here now:
> On Mon, Jun 8, 2009 at 5:24 PM, Markus
> Neteler<neteler at osgeo.org> wrote:
> > hi,
> > I am trying to reproject the Swiss CORINE data CLC90 [1] into LAEA.
> > The .prj file is attached. Unfortunately the transformation fails:
> > ogr2ogr -t_srs eu_etrs89_laea.prj /tmp/clc90_eu_laea.shp
> /geodata/clcbn85p.shp
> > ERROR 6: Failed to initialize PROJ.4 with `+proj=omerc
> > +lat_0=46.95240555555556 +lonc=7.439583333333333 +alpha=90 +k=1
> > +x_0=-9419820.590700001 +y_0=200000 +ellps=bessel +units=m
> +no_defs '.
> > lat_0 = 0 or 90 or alpha = 90
> > Failed to create coordinate transformation between the
> > following coordinate systems.  This may be because they
> > are not transformable, or because projection services
> > (PROJ.4 DLL/.so) could not be loaded.
> > Source:
> > PROJCS["Bessel_1841_Hotine_Oblique_Mercator_Azimuth_Natural_Origin",
> >    GEOGCS["GCS_Bessel_1841",
> >        DATUM["Not_specified_based_on_Bessel_1841_ellipsoid",
> >            SPHEROID["Bessel_1841",6377397.155,299.1528128]],
> >        PRIMEM["Greenwich",0.0],
> >        UNIT["Degree",0.0174532925199433]],
> >    PROJECTION["Hotine_Oblique_Mercator"],
> >    PARAMETER["False_Easting",-9419820.5907],
> >    PARAMETER["False_Northing",200000.0],
> >    PARAMETER["Scale_Factor",1.0],
> >    PARAMETER["Azimuth",90.0],
> >    PARAMETER["Longitude_Of_Center",7.439583333333333],
> >    PARAMETER["Latitude_Of_Center",46.95240555555556],
> >    UNIT["Meter",1.0]]
> > Target:
> > PROJCS["ETRS89 / ETRS-LAEA",
> >    GEOGCS["ETRS89",
> >        DATUM["European_Terrestrial_Reference_System_1989",
> >            SPHEROID["GRS 1980",6378137,298.2572221010042,
> >                AUTHORITY["EPSG","7019"]],
> >            AUTHORITY["EPSG","6258"]],
> >        PRIMEM["Greenwich",0],
> >        UNIT["degree",0.0174532925199433],
> >        AUTHORITY["EPSG","4258"]],
> >    UNIT["metre",1,
> >        AUTHORITY["EPSG","9001"]],
> >    AUTHORITY["EPSG","3035"]]
> > Suggestions welcome to reproject this data set...
> > thanks
> > Markus
> > [1]
> http://www.bfs.admin.ch/bfs/portal/de/index/dienstleistungen/g
eostat/datenbeschreibung/corine_land_cover.html
>    Data: -> GIS-Daten CORINE Land Cover Schweiz 1990 (ZIP file)
Is there a way to enable PROJ4 to support this projection?
thank in advance,
Markus
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090710/e641810d/attachment.html>
