[Proj] Geodesic distances away from the ellipsoid
Karney, Charles
ckarney at Sarnoff.com
Sat Jul 11 09:03:17 PDT 2009
> From: Jay Hollingsworth <jhollingsworth at houston.oilfield.slb.com>
> Sent: Fri 20-Mar-09 11:56
> Subject: [Proj] Geodesic distances away from the ellipsoid
> At the risk of asking a dumb question, do any of the geodesic
> algorithms allow calculation of the geodesic distance if the path is
> not on the ellipsoid? Like in an airplane or satellite whose path
> could be assumed to be a constant height above the ellipsoid?
The paper
Richard Mathar
Geodetic Line at Constant Altitude above the Ellipsoid
http://arxiv.org/abs/0711.0642
addresses this problem. However, I believe there is a simple solution.
Let E be the ellipsoid and S a surface a constant height h above it.
A normal section through a point on E is a normal section through the
corresponding point on S. Thus mapping a geodesic on E to S by
elevating it by h results in a geodesic on S. This directly gives you
the course of the geodesic. A little extra work gives you the azimuth
and length.
A couple of questions suggest themselves:
(1) is this observation true?
(2) is it new?
Charles Karney <ckarney at sarnoff.com>
Sarnoff Corporation, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
Fax: +1 609 734 2662
More information about the Proj
