[Proj] Change in +prog=eqc behavior from 4.5.0 to 4.6.1
Glynn Clements
glynn at gclements.plus.com
Thu Jul 16 16:43:12 PDT 2009
Orion Poplawski wrote:
> On 07/16/2009 02:29 PM, Orion Poplawski wrote:
> > Turns out that somewhere between glibc 2.9 and 2.10.1, atof/strtod for
> > "5.3049894774131808e-315" starting setting errno to ERANGE. Having
> > errno set causes pj_init to abort. I believe this is a bug in glibc
> > (file here: http://sourceware.org/bugzilla/show_bug.cgi?id=10404).
> Well, apparently the glibc maintainer doesn't agree with me (big
> surprise),
C99 and POSIX permit atof() to set errno to ERANGE on underflow. C99
permits strtod() to set errno to ERANGE on underflow, while POSIX
requires it.
More information about the Proj
