[Proj] Need help converting Goode to latlon
support.mn at elisanet.fi support.mn at elisanet.fi
Thu Jul 23 12:34:17 PDT 2009
Hello
I am almost 100% sure that the problem is wrong central
meridian, since the resulting picture shows increasing
error to the north and south. Goode projection does just
that if the central meridian (lon_0) is wrong.
The data is on Americas and that uses usually lon_0=-90.
If the inverse uses lon_0=0, the distortion is evident.
Do some experimenting with lon_0 (central meridian).
Janne. / MNS Support
