[Proj] Need help converting Goode to latlon
Gerald I. Evenden
geraldi.evenden at gmail.com
Thu Jul 23 16:37:55 PDT 2009
On Thursday 23 July 2009 4:23:07 pm Melita Kennedy wrote:
> -----Original Message-----
> >Message: 2
> The 'option' parameter is used to determine whether to use the 'land' or
> 'ocean' version. That is, if '1', the interruptions will occur in the
> oceans. If '2', the interruptions will occur on land. The standard Goode's
> (land) prj file is using WGS84, so the radius is 6378137.0.
> Melita Kennedy
> ESRI, Inc.
If the interupted version of Goode is used then *NO* standard version of
[l]proj will handle it without the user segmenting the data into the
subregions of the interuptions.
A closer examination of jpeg does seem to verify the idea of an interrupted
projection.
As an aside, for the America continents segment: +lon_0=-100. In addition,
one needs the appropriate +x_0=-1.745329 for unit sphere (multiply that value
by the radius used to get a proper value for this case). These values apply
for Goode's land map.
In addition, because of the wide variation of segmentation used, it is not
likely that a proj inverse for segmented projections will be an integral part
of the basic software.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
More information about the Proj
