[Proj] Proj cannot been found by postgis
Pena Kupen
kupen at wippies.fi
Thu Jul 30 00:19:40 PDT 2009
Hi all,
I'm new on this list.
I have problem when try to install postGIS from distro repo. I think my problem is installation of proj from source?
*I'm using CentOs 5.3
*Postgres 8.4. installed from rpm
*Proj.4 4.6.1 from source
*CEOS 3.1.1 from source
*try to install PostGIS 1.3.6 from repo with yum, but I got dependency errors:
yum install postgis
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* updates: centos.siirappi.com
* base: centos.siirappi.com
* addons: centos.siirappi.com
* extras: centos.siirappi.com
Setting up Install Process
Parsing package install arguments
Resolving Dependencies
--> Running transaction check
---> Package postgis.i386 0:1.3.6-1.rhel5 set to be updated
--> Processing Dependency: libgeos_c.so.1 for package: postgis
--> Processing Dependency: proj for package: postgis
--> Processing Dependency: libproj.so.0 for package: postgis
--> Processing Dependency: /usr/bin/rebuild-gcj-db for package: postgis
--> Processing Dependency: geos for package: postgis
---> Package geos.i386 0:2.2.3-3.rhel5 set to be updated
---> Package java-1.4.2-gcj-compat.i386 0:1.4.2.0-40jpp.115 set to be updated
filelists.xml.gz | 139 kB 00:00
filelists.xml.gz | 1.9 MB 00:00
filelists.sqlite.bz2 | 109 kB 00:00
--> Processing Dependency: jpackage-utils >= 1.6.6-1jpp_1rh for package: java-1. 4.2-gcj-compat
--> Processing Dependency: libgcj >= 4.0.0-0.42 for package: java-1.4.2-gcj-comp at
--> Processing Dependency: /usr/bin/rebuild-security-providers for package: java -1.4.2-gcj-compat
--> Processing Dependency: /usr/lib/gcj-4.1.1/libjvm.so for package: java-14.2- gcj-compat
--> Processing Dependency: /usr/bin/gcj-dbtool for package: java-1.4.2-gcj-compa t
--> Processing Dependency: /usr/bin/gij for package: java-1.4.2-gcj-compat
--> Processing Dependency: gjdoc for package: java-1.4.2-gcj-compat
---> Package jpackage-utils.noarch 0:1.7.3-1jpp.2.el5 set to be updated
---> Package libgcj.i386 0:4.1.2-44.el5 set to be updated
---> Package gjdoc.i386 0:0.7.7-12.el5 set to be updated
--> Processing Dependency: antlr for package: gjdoc
---> Package antlr.i386 0:2.7.6-4jpp.2 set to be updated
--> Finished Dependency Resolution
postgis-1.3.6-1.rhel5.i386 from pgdg84 has depsolving problems
--> Missing Dependency: proj is needed by package postgis-1.3.6-1.rhel5.i386 ( pgdg84)
--> Missing Dependency: libproj.so.0 is needed by package postgis-1.3.6-1rhel 5.i386 (pgdg84)
Error: Missing Dependency: proj is needed by package postgis-1.3.6-1.rhel5.i386 (pgdg84)
Error: Missing Dependency: libproj.so.0 is needed by package postgis-1.3.6-1.rhe l5.i386 (pgdg84)
At least libproj - files are there
/usr/local/lib/libproj.a
/usr/local/lib/libproj.la
/usr/local/lib/libproj.so
/usr/local/lib/libproj.so.0
/usr/local/lib/libproj.so.0.5.5
What am I missing?
pk
Saunalahti DataPaketti - tilaa nyt, saat 2 kk veloituksetta ja Nettitikun kaupan päälle!
http://saunalahti.fi/gsm/gsmdatapaketti.php
More information about the Proj
