[Proj] Proj cannot been found by postgis
Pena Kupen
kupen at wippies.fi
Thu Jul 30 21:51:53 PDT 2009
Yeps you are right. I found reason for that:
Yum's CentOS-Base.repo file was not updated.
"In yum repo there where no exclude for postgres*. I add on sections [base] [upddates]
exclude=postgresql*"
And Google is fast!
pk
David Turover <dturover at student.santarosa.edu> kirjoitti:
> On Thu, Jul 30, 2009 at 10:19:40AM +0300, Pena Kupen wrote:
> > I have problem when try to install postGIS from distro repo. I think my problem is installation of proj from source?
> yum might be looking for proj in its own database of installed rpms, in
> which case it would not find anything that was compiled manually.
> The easy solution, if possible, is to get an official rpm of proj from
> your distro.
> But it looks like you already know this (and Google is fast):
> http://www.linuxforums.org/forum/redhat-fedora-linux-help/150648-solved-centos-yum-dependency-problem-postgis.html
> - David T.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Saunalahti DataPaketti - tilaa nyt, saat 2 kk veloituksetta ja Nettitikun kaupan päälle!
http://saunalahti.fi/gsm/gsmdatapaketti.php
More information about the Proj
