[Proj] How to Reengineering the cs2cs tool
Tamas Szekeres szekerest at gmail.com
Thu Jun 4 12:10:54 PDT 2009
You could also try the GDAL SWIG Perl bindings which also wraps some proj4
functionality. You might want to use
CoordinateTransformation.TransformPoints to transform multiple points in a
single call.
GDAL also have php bindings but there's no active maintainer to keep this
stuff in a good condition.
Best regards,
Tamas
2009/6/4 BalaVignesh Kasinathan <kbalavignesh at gmail.com>
> On Thu, Jun 4, 2009 at 2:20 PM, BenoƮt Andrieu <bea at ixsea.com> wrote:
>>  Can't you call directly the proj dll or wrap it in order to use it
>> directly from your php / perl code ?
>> It seems dangerous to me to recode everything.
> Hi Andrieu,
>   Yes i can call the cs2cs binary directly from php code but it gives some
> performance issues.
>   I need to do 100 s of convertion at the time. So that only i am trying to
> develop on the native language (php code).
> Regards,
> Bala
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090604/b95c9f03/attachment.html>
