[Proj] How to Reengineering the cs2cs tool
BalaVignesh Kasinathan
kbalavignesh at gmail.com
Fri Jun 5 06:08:25 PDT 2009
On Thu, Jun 4, 2009 at 8:35 PM, Gerald I. Evenden <geraldi.evenden at gmail.com
> wrote:
> I sincerely hope you reevaluate your problem.
Thank you very much for all your replies.
Yes , i am reevaluating my problems. At the same time i am keep on trying
to do it in php by tracing the code. When i finish the work , i will
benchmark the performance with existing method (Where i am accessing the
cs2cs binary from php code).
Also i am trying to understand the documents but as you mentioned i find
dificulties to understand it.
Regards,
Bala
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090605/e7e20b26/attachment.html>
More information about the Proj
