> This means that you can't use something like:
> while (more coordinates) {
> send input to cs2cs
> read output from cs2cs
This sort of code is generally a bad idea as its behavior depends on the
OS and the program you are calling.
In the old days, I would have used a temp file, but now I'd consider
threads.
-- Karl
