[Proj] Unicode
Gerald I. Evenden geraldi.evenden at gmail.com
Mon Jun 8 11:34:24 PDT 2009
On Monday 08 June 2009 1:54:55 pm Glynn Clements wrote:
> support.mn at elisanet.fi wrote:
> > if there are any issues with any text files I would very much recommend
> > to use Unicode.
> There aren't any issues with text files.
> I can think of precisely two cases where PROJ *might* want to use
> characters outside of the ASCII repertoire:
> 1. Correct spelling of "Plate Carée".
You forgot Hözel, Larrivée, Putniņš projections to name a few.  Tsk, tsk.
I am not too sure on the details of the last as the s shown is with a caron
but it may be more proper with a breve.  Also the n is done elsewhere with
a "dot" rather than the cedilla shown here.  But whatcha going to do?
And, of course, Krüger!  How could we forget?
> 2. The degree symbol.
> I can't see how either of these could be sufficiently important to be
> worth the effort of dealing with the morass of issues related to text
> encodings.
Besides, why take up vast quantities of bytes with 16 bit code where special
inline doublet or triplet escape coding like LaTex uses can do the job with 7
bit ASCII with ease.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
