[Proj] NADCON, et al.
Glynn Clements
glynn at gclements.plus.com
Sat Jun 13 13:11:57 PDT 2009
Gerald I. Evenden wrote:
> The following is something that should work on Linux and probably BSD, Unix
> but I have *no idea* if it will work on any of the Microsoft compilers. If
> anyone is so inclined could you compile and test the following.
MSVC doesn't have readdir().
MinGW has readdir(), but the d_type field isn't present.
POSIX only specifies d_name; d_type originates from BSD, and isn't
generally found on SysV-derived Unices. Even on Linux, only some
filesystems support it.
If you want better portability at the expense of performance, use
stat() rather than the d_type field.
More information about the Proj
