[Proj] PROJ and M$
support.mn at elisanet.fi support.mn at elisanet.fi
Mon Jun 15 16:25:16 PDT 2009
Hello,
You can also download the free Visual C++ Compiler (Express
Edition) from Microsoft!
http://www.microsoft.com/express/vc/
Note that unlike the commercial Visual Studio Professional 2008,
it does not have MFC, ATL, a Win32 resource editor, a macro
assembler, source code control integration, etc.
If you only do some library programming, you will not need MFC or
ATL libraries. And the missing resource editor can be replaced by
several free resource editors available, for example:
http://www.resedit.net/
More free C/C++ compilers, see:
http://www.thefreecountry.com/compilers/cpp.shtml
Regards: Janne.
"Gerald I. Evenden" [geraldi.evenden at gmail.com] kirjoitti:
> My question to the practicality oriented: is there any problem using minGW on
> a 64 bit XP and generating DLL's and exe's good for any M$ machine?
