[Proj] Rotated Polar Stereographic Projection in Proj4
Alexander Jarosch ajarosch at eos.ubc.ca
Thu Mar 5 13:58:39 PST 2009
Gerald I. Evenden wrote:
> On Thursday 05 March 2009 2:40:53 pm Alexander Jarosch wrote:
>> Hello!
>> I have a rather simple question, but I could not find any documentation
>> so far on how to do this with proj4. A college of mine has maps on a
>> "polar stereographic projection" with the following details:
>> Pole_lat = 50.0
>> Pole_lon = -150.0
>> Central_lat = 50.0
>> Central _lon = -126.0
>> These are the definitions he gave me. Now I think this is a
>> stereographic projection with a given pole lat/lon and should maybe not
>> be called polar stereographic, but that is not the problem. I want to
>> set up proj4 (or cs2cs for that matter) to this projection to transform
>> coordinates from lat/lon and I assume the same ellipsoid. My problem is
>> that I did not find any documentation on how to set up this rotated
>> stereographic projection with proj4.
>> Any help would be really appreciated.
> Appears to be a truely oblique projection and not in the tradition of
> proj=stere where the pole is on the CM.
> Is a spherical earth used?  In the case of a spherical earth one could use the
> combination of proj=ob_tran and stere.  Otherwise, if it is a azimuthal
> stereographic, I do not know of anyway proj or libproj could handle it
> without development.
> Sheeesh.  I wonder what the rational for this beast was?  Class exercise?
Nope that beast comes from a climate model ;-). Anyway, is it fairly
simple to work out the combination of +proj=ob_tran and stere for this
projection I mentioned, because it assumes a spherical earth, like
almost all climate models.
Thanks.
Alex
Alexander H. Jarosch
Post-Doctoral Fellow
Department of Earth and Ocean Sciences,
The University of British Columbia,
6339 Stores Road,
Vancouver, British Columbia
Canada, V6T 1Z4.
Tel.: +1 604 822 3063
Fax.: +1 604 822 6088
