[Proj] Create custum projection definition PROJ4 for rwanda
Frank Warmerdam
warmerdam at pobox.com
Mon Mar 16 09:20:11 PDT 2009
Lavver wrote:
> Hi,
> I'm struggling to create a custom projection definition for QGis for the
> national system used for Rwanda. I am new to the PROJ.4 syntax.
> The ArcView prj file (which works fine) shows:
> PROJCS["Rwanda1",GEOGCS["GCS_Clarke_1880",DATUM["D_Clarke_1880",
> SPHEROID["Clarke_1880",6378249.138,293.466307656]],
> PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],
> PROJECTION["Gauss_Kruger"],
> PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",10000000.0],
> PARAMETER["Central_Meridian",30.0],PARAMETER["Scale_Factor",0.9999],
> PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
> I translated it to
> +proj=tmerc +ellps=clrk80 +a=6378249.138 +rf=293.466307656 +lon_0=30
> +k=0.999900 +units=m +x_0=500000 +y_0=10000000
> But I'm still 200m to 300m away from reality
> The following WGS84 N/E coordinates should give the projected Coordinates
> -1.57741 N /29.93690 E => 9825897/492907
> -1.57763 N /29.93723 E => 9825873/492943
> -1.61141 N /29.92847 E => 9822138/491968
> Could someone help me please ? Maybe I am omitting a parameter...
Lavuun,
It sounds to me like you are running into datum shifting issues.
I think you need to determine acceptable "towgs84" parameters for
your datum (D_Clarke_1880 isn't really a datum description by
the way, it just says it is a generic datum based on the Clarke 1880
ellipsoid).
This material on towgs84 may be somewhat helpful:
http://trac.osgeo.org/proj/wiki/GenParms#towgs84-DatumtransformationtoWGS84
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
