[Proj] lat/long to northing/easting and back again
Christopher Barker Chris.Barker at noaa.gov
Tue Mar 17 09:16:57 PDT 2009
Roger Oberholtzer wrote:
> We need to involve the odd gyroscope, inclinometer, and pulse distance
> transducer at this point. All are calculating distances in meters.
going lat-long to meters isn't so hard -- in fact, if I'm right about
geodesics (geodetics?) that's exactly what you can do:
start at point A, and go X meters at a given bearing, and it tells you
where are you are in lat-long.
> Our data is tagged with time that has been synchronized with our GPS.
> When we want to know where we are, we start by determining when we were
> at the point we want to know the location of.
you should be able to do this in lat-long too.
I guess my thought is that if you have a bunch of data in a given
projects, then by all means use it. But if you are only going through a
projection to do geometric calculations, then going back to lat-long,
you may well be better off staying in lat-long.
> The distances are luckily too small to have to involve the great circle.
Then it really doesn't matter much how you do it! -- you could probably
stick to spherical geometry, or even straight Cartesian in lat-long and
be fine.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
